Yet Another Route 66 question !! N95
3 replies · 6,932 views · Started 14 August 2007
Hi can i ask is it perfectly ok for me to buy my brothers copy of route 66 ? he just bought a brand new route 66 and the guy needed his imei number? so what i need to no is it ok for me to buy it and use it on my N95,
Just a liitle concerned on the imei situation.
Hope to hear soon oh and hes also getting error messages when trying to install route 66 saying "MISSING RESOURCE FILES PLEASE RELOAD " !!
Many thanks from brian
readbmr wrote:Hi can i ask is it perfectly ok for me to buy my brothers copy of route 66 ? he just bought a brand new route 66 and the guy needed his imei number? so what i need to no is it ok for me to buy it and use it on my N95,
I think, he bought an illegal copy of Route 66 . . .
You don't need to provide your IMEI-nr, when installing Route 66 (unless it's an unsigned/cracked copy)!
the "MISSING RESOURCE FILES PLEASE RELOAD" is usually seen when you haven't installed all the files from the DVD.
If my memory is correct, the route66 DVD has a folder called something along the lines "copy to root of memory card" and in this folder there are a bunch of xtra files the app needs, like fonts, sounds etc....
hope this helps,
ut.
