It's one of the small problems I have with the phone so far.
When you slide it shut it say's "Lock keypad?" and you have to press yes or no. I find it VERY annoying. Is there a way to remove that message?
whats so annoying?? You close it... and you either press yes to lock it or ignore it?
On the N95, when you close it, it automatically locks the keypad. Much less annoying than being prompted.
Is it possible to have that same behaviour in the N80. Close it and it just locks?
yeah you can do... but you need a new app like handy lock or erm, another lock program that I had but cant remember the name of.
Handy Lock is the app you want. When you close the slider it automatically locks.
