gps on n95 and e90 different?
3 replies · 2,142 views · Started 15 August 2007
i have both e90 and n95 and am thinking of selling my n95 because it is pretty much the same as my e90 but 1 query though
on my n95, there is an option on the gps that says tracking. it guides me through the place i am going to but without voice guidance. on the map it shows where i am and provides a highlight of the route i am going to.
on my e90, it only shows where i am and it doesn't highlight my route.
is this normal?
What programs are you using? Is it both nokia maps?
If so, check you have the same version on both, as I heard they made some updates on it a while ago.
Also check you have the options set the same.
Nokia maps is free I beleive. However, if you want spoken turn by turn guidance you have to pay a subscription.
If you want anything else, you have to pay for it.
