Calender Help!!!
5 replies · 2,150 views · Started 16 August 2007
Hi all,
How do i access the calender on my N95 via anything other than outlook? (don't have it).
I've recently flash upgraded my handset and the backup lost my calender references, it's frustrating enough to have to re-type them all in again but i would like to do it on my PC in rather than on the handset.
Thanks.
Havent tried it myself but can't you use PCSuite to sync with Outlook Express (comes with XP)?
If not you'll have to try one of the netbased calender services like 'Google Calendar' and use 'GooSync' to synchronize it with N95.
Outlook express does'nt have a calender on it, and I do use google calender at the moment but 'Goosync', is not free plus the fact i can't seem to get it to work, and i only really want to do it once.
Thanks anyway, ill just have to sit down and spend some time on it.
Oxygen Phone manager II has the ability to read/write contacts and calender data and back them up.
I feel for you, this happened to me also. i did a back up using the memory application and when i restored it a few days later it resotored everything except all my calendar entries. Not acceptable if you ask me, this has always worked on my previous symbian Nokia phones
Nokia N95 is supported in Oxygen Phone Manager for Symbian OS phones. This program allows you to read data from phone, edit it, save in various file formats and then write data back to phone.
