Backing up N80 to use on new N95
2 replies · 2,763 views · Started 17 August 2007
Have an N80- getting an N95.
If I use Content Copier on PC Suite, can I simply upload that backup file into the new N95?
What other backup methods would you recommend to be on the safe side (contacts and calendar are most important to me). Any way to just copy these onto a file on my PC?
Regards
The N95 does come with the Transfer app.
You can also use PC Suite v6.84 to back up the N80 and then restore what can be restored to the N95 using the same PC Suite version.
