Help with N95 Super@ Settings Please
1 replies · 2,851 views · Started 17 August 2007
Hi, ive downloaded the super@ Video convertor and i keep getting error messages !!!! ive only managed to do one but also need the correct settings in order to play either in avi with the divx player or smartmovie, best quality the better,
Many thanks and hope to hear from you guys who have done this and what settings you are using and what players you use with best quality .
Thankyou
If you use Smartmovie, use the smartmovie converter.
If you want to use the built in player, I use these and got great results
container: mp4
output video codec: h.264/AVC
output audio codec: AAC
video size: 320:240
aspect: 4:3
frames per sec: 25
bitrate: 528
options: hi quality 48k audio
sampling frequency: 24000
channels: 2
bitrate: 64
