I'm getting strange characters displayed on my N95 screen saver and Calculator.
For instance, instead of the time displayed I'm currently showing '*)2-/' (real local time is 9:57pm) on the screensaver.
Also the Calculator function is unusable, as pressing 1 shows as '😉', 2 shows as '*', 3 shows as '+' etc. etc.
Anyone know what's causing this?
I did change the product code from O2 UK code to a 'Euro 1' one and update to Firmware 12. Could this have caused it? Anybody else had this problem?
Makes it ruddy impossible to tell the time from the screensaver :frown:
Yeah I tried that. I'm using Blue Dots theme, but I still get the problem even if I use any of the Nokia default themes or any other theme.
I notice on the clock on the homescreen, that the character at the 3 o-clock position is also displaying symbols instead of a number (Date/hour?).
I've installed the 3rd Party Calcium calculator, and thankfully that works fine, so I'm not without a usable calc. Also Dialing numbers display perfectly.
I've done 'battery-out' resets etc, but all to no avail. Strange problem this.
Either it's a faulty handset in some way, or there's some setting I've changed that has caused this display fault.
Is your phone set to English?
tonymy01 wrote:Is your phone set to English?
And is your writing language set to English?
Good point!
Erm, how do I check/change those settings please?
Update: Just found Phone and Writing language set to English. Unless there's some phone code settings I can access to change some more fundamental settings?
I don't know if it's related, but any web page I access on the N95 displays all the text in some Gothic font, not a normal one like Ariel or Times New Roman. Very annoying and I don't know how to change this either!
Fixed it!
Turns out some app I loaded had put some strange fonts in the Mem Card \Resource\Fonts folder.
I used the instructions here...
darlamack.blogs.com/darlamack/2007/05/changing_fonts_.html
and changed all the fonts to Arial (renamed to S60 3rd Edition naming conventions), rebooted, and everything's back to normal.
Happy days 😊
