Does the liquid spray that comes with the invisible shield damage the screen or circ
3 replies · 2,682 views · Started 18 August 2007
Guys I have bought the Invisible shield full body shield for my n95 i am wondering as it comes with a spray that you must spray on both side of the cover could it damage the screen in anyway
If is that kind of liquid used for clean SLR lens, no.Others, you may take care if they are acid, because it can be damaged.
I don't know about that particular spray, but WD40 most definitely DOES get under the screen - it causes a big darkened "blob".
My thoughts: I will NEVER use another spray EVER near the N95 screen.
If you do use it, I'd avoid spraying it anywhere near the gap around the screen.
Blimey, that's the most caps I've ever used in a single post......
WD40 - Never... Only grass remover liquids like the ones used on cleaning procedure of SLR lens.
