Hi all
Been trying to update my 95 with the Nokia software updater but it keeps tell me the latest up date available is V.11 witch i already have
My phone was on T mobile but unlock working on 3 product code 0546659
Can any one help??
Thanks Jay 😊
Hi all
Can any one help??
Thanks Jay 😊
I don�t understand what do you mean exactly... If is a network lock version maybe that is the reason why it does not allow the upgrade process.
JayMann wrote:Hi allBeen trying to update my 95 with the Nokia software updater but it keeps tell me the latest up date available is V.11 witch i already have
Can any one help??
Thanks Jay 😊
jay iam sure i awnswerd this for you the other day
software updates are avalible for certain product codes only
0546659 is probs a tmobile branded handset so youll have to wait for tmobile to release there version of v12 firmware nokia release it for their sim free handsets they sell (generic nokia) 1st you have a tmobile nokia so youll have to wait for tmobile to do there bit which can take ages
or you can change your product code to a generic nokia code and update like that via nokia software updater
its very easy and loads of guides all over the net probs about 5 on this website alone 😊
at the top of this forum is all the product codes for the n95 just choose the one for your region change the code with nemisis service suite which is a free download then use nsu to update 😊
youll void your warranty so after update change your product code back to original mate just incase this wont guarantee you still have warranty as you will prob have firmware that wasnt released for your product code yet
anyways hope that helps
hi there what product code are you using?
Thanks for that
Yes it is a Tmobile branded handset and i payed them to have it unlock
Think i may just wait and them to release an update as i used NSD yesterday and i now have lost all my contacts, text, bookmarks and settings not happy! 😡
craig law wrote:hi there what product code are you using?
0546659 that's what it says on the back of the phone is that right?
yeah. do you have nemisis service suite?
No i don't
jay you will allways loose your data on phone with a firmware upgrade
allways do a backup to memory card or pc of contacts etc 1st
thats the only way to avoid it
thanks
buxz777 wrote:jay you will allways loose your data on phone with a firmware upgradeallways do a backup to memory card or pc of contacts etc 1st
thanks
Yeah i know mate but i didn't do an update NSD just told me that the only update was the one i already had!?
Change ur product code to a EURO one using NSS (google how to do that) then try NSU
Ull void ur warranty thou
OK thanks will try
thanks
NEVER restore a backup after Firmware changes or upgrades!!!!!
You can safely use PC Suite Synchronise and Contenct Copier, but don't use the PC Suite Backup tool or the Memory Card Backup tool in the handset.
dez_borders wrote:NEVER restore a backup after Firmware changes or upgrades!!!!!
and why is that?
ddidds wrote:and why is that?Good question since this is what Nokia Software Updater tells you to do!
Because it restores not only your data, but also the menu structure and system data that worked on the old/branded Firmware but often conflicts on the new Firmware. Many N-Series owners have experienced problems adter restoring a backup from one FW version onto a handset with newer FW.
It's best to only use PC Suite Synchronise function to backup & restore for Contacts, Calendar, Bookmarks etc.
Hi
Is there a How to guide on change product code? Think i'll try that
Have just had a look for nemesis service suite on their site but can't find a like to download it
JayMann wrote:HiIs there a How to guide on change product code? Think i'll try that
http://www.youtube.com/watch?v=uN9eRlddfH0
has all the links to the software you'll need and a few tips too.
Good Luck!😊
dez_borders wrote:Because it restores not only your data, but also the menu structure and system data that worked on the old/branded Firmware but often conflicts on the new Firmware. Many N-Series owners have experienced problems adter restoring a backup from one FW version onto a handset with newer FW.
nice one.thx!
Actually you can restore contacts just FINE from the backup with different firmware / product serial codes.
Its the 'model specific settings' which you should under no circumstance restore.
