Phone Rebooting problem and Phone Call problem
7 replies · 1,966 views · Started 19 August 2007
Got my Nokia N95 a few weeks ago but recently when someone tries to phone me or i try to phone someone, i can hear what theyre saying but they (obviously) cant hear what im saying. Anyone else had this problem and is it something wrong with the settings that can be fixed or would i need to take it back :frown:
Also today when i tried phoning someone, the phone cut to a black screen and came up white with the Nokia logo, then sort of rebooted itself 😡
The rebooting happens more when i try to use WAP or the Internet browser.
I open it up and its usually when its searching for access points or the GPRS that it cuts off and reboots again. Although sometimes it does this when im in the middle of browsing :icon13:
Anyone had these problems and is it something that can be fixed?
kvee wrote:I have same problem 😞 / firmware 12.0.013 /
are you guys on o2??
i had the same prob on n73 untill i updated firmware which obvously you cant do as we have the latest
mine is ok at min but defently had this on n73 i blamed o2 but not to sure now
hope you get it sorted i had to reboot phone which was a pain
robrangers wrote:Got my Nokia N95 a few weeks ago but recently when someone tries to phone me or i try to phone someone, i can hear what theyre saying but they (obviously) cant hear what im saying. Anyone else had this problem and is it something wrong with the settings that can be fixed or would i need to take it back :frown:
If it's just started doing this then it's more than likely something you've installed causing a clash!
What browser and apps are you using and where have you installed them?
I believe it is a bug in V12 firmware, I have this too (sometime) , and I heared it happened to some other people , the phone sometime can't respond or get freezed if I use the keys in a fast way.
I don't have N95, but as I said about v12 firmware, it does not have this fault. Try to reset all your settings, and if problem persists, try to reset all the phone and format your memory card. If problem persists, it's better to contact your Nokia dealer and ask for support.
I too believe this a bug in the V12 firmware as mine only started to do this after upgrading. Mine does it when listening to normal FM radio, and sometimes when receiving a call. It does not happen a lot but it is a pain when it does.😡
Well it happened before i upgraded the firmware. Last night i upgraded it on the Nokia site (dont know what Version it was)
Only made a few calls today and theyve worked but one person i was talking to said it was a bit crackly so im guessing it will happen again
