Can you change the Icons in Applications, or is there a Theme Editor
1 replies · 2,545 views · Started 19 August 2007
I had the SE K750i before this phone and it came with a theme editor so you could edit it your own and put it in your phone, is there a version for the n95?
Also is there anyway to edit the icons or widgets (?) like if youve downloaded an application that has a crappy icon?
do a search on google for "theme DIY" it's an editor that you install on your phone and you can fiddle about with it that way. There's not much you can do with it compared to a pc based one but it's good fun to play with when you have idle fingers 😊
