Multimedia Converter Pro's error while converting clips
2 replies · 7,663 views · Started 17 January 2003
Hi all,
I'm Phi.
I'm new, just got a 9210i recently. To be honest, I' not really good at converting video clips or stuff like this. I downloaded Multimedia Converter Pro and tried to convert , but it found an error when the program started converting.
I use WIN XP Pro , it came up a pop up saying :"Multimedia Converter Pro for Nokia 9210 Communicator has encountered a problem and needs to close. We are sorry for the inconvenience."
...blah blah....Please tell Microsoft about this problem. We have created an error report that you can send to us. We will treat this report as......."
These are the steps that I took:
_I use VCD cutter V4.03 to create a clip. the file I create is MPEG
_ Then I use Multimedia Converter Pro to convert this file, setting 128 for image size, quality 4 , fps is 7.5
_ Finally, when I click on CONVERT, then it found this error which is very disapointing!!!
is it WIN XP problem?
Can anyone help me? I really appreaciate your help!!!
and please forgive my English, I know it 's horibble!!! 😉 😉
Many Thanks
Umbro
Hi all again,
just did a research in here and I found that many people got the same problem. MMC doesn't work on P4 PCs.
that could be the answer because I'm using a Pentium 4 PC....gosh....bad luck!!!!
