Keeping screen lit when slider open
3 replies · 3,114 views · Started 20 August 2007
I've been using app BestProfiles to keep the screen lit when phone is on charger. This is very handy when in car with phone in dash-mount. However, I was won dering if there is any app that can keep screen lit when the slider is open ? That would be even better than BestProfiles, as I don't use that app for switching profiles anyway. Thanks.
I never try, so not sure, if turn off all screen protection can keep the light�s on. On previous OS, there is on FExplorer that option, so, maybe there is also on Beta from FExplorer for OS9... maybe...
HI Daffie, I use light on. With this application you can turn the lights on and off when you want. Google for it or try Nokia website.
Hope this helps
DJ Mike wrote:HI Daffie, I use light on. With this application you can turn the lights on and off when you want. Google for it or try Nokia website.
Hope this helps
Thanks for the input, however I've tried this app. There doesn't seem to be an app out there that keeps screen lit when slider is opened. Too bad 😞
