nokia 6680 lock code
2 replies · 8,598 views · Started 21 August 2007
i lost my nokia 6680 but found it the other day, i had a lock code on it and i can't remember it. can any one please help?? i tried lookin through the threads, i looked for firmware update but this is no use as i can't turn the phone on without the lock code and it can't connect. I can't even get imei number, all i have are the codes on d back
355661/00/384603/7
code: 0516031
FCC ID: PDNRM - 36
IC: 661R-RM36
Go to a Nokia Service and make the prove that you are the owner, and they can unlock the device.
Hey cool,
This is somewhat related to security unlock. So you will need the master reset code which will be available on net. You can browse through google to reset your phone.. You will be able to get unlock codes at low cost for all gsm phones here http://www.theunlockarena.com/ if your phones got network locked.. All you have to do is to check your phone model and service provider. Type *#06# to get your imei number on your mobile.
Cheers!
