I have my n95 firmware up to date (12.0.0.013) but I can only choose from English, Melayu and Mandarin (i think) as writting and phone languages, I tried changing the product code with NSS to EURO1 Plum (0536062 - since I just need Spanish as writting language) but when I run the Nokia updater after it says my firmware is up to date so i cant "re-install" it, is there a way to add the EURO1 language pack to my phone? what am I doing wrong here? :con?
Thanks in advance.
PD: Those languages were the same I could choose from when I just got the phone with the old firmware.
you didn't have the write [] box checked using NSS .. rerun it .. make sure you have changed the product code.
confirm that by rerunning NSS again .. or use *#0000#
-- give that a try
Good Luck!😊
its checked and I cheked it again and it shows the product code I changed, any other ideas?
vengiss wrote:Hi,I have my n95 firmware up to date (12.0.0.013) but I can only choose from English, Melayu and Mandarin (i think) as writting and phone languages, I tried changing the product code with NSS to EURO1 Plum (0536062 - since I just need Spanish as writting language) but when I run the Nokia updater after it says my firmware is up to date so i cant "re-install" it, is there a way to add the EURO1 language pack to my phone? what am I doing wrong here? :con?
Thanks in advance.
This WILL allow you to update over the same version firmware.
http://www.youtube.com/watch?v=uN9eRlddfH0 << has links to the updater etc.
Try again with the stand alone updater and report back. Good Luck!😊
No luck 😞 I remember I had the option to resinstall the firmware with the nokia updater, but I dont know why I dont have it know it just wont let me install it again since I have the latest one...
