Hello.
If you look at the bottom of the screen at a 80-85 degree angle, do you see well... a brighter spot beneath the cover left of the d-pad?
Thanks.
Hello.
Thanks.
sln wrote:If you look at the bottom of the screen at a 80-85 degree angle, do you see well... a brighter spot beneath the cover left of the d-pad?
Yes, I can see the light! 😉
The E61i of a collegue has the same light - so it's no failure!
Regards
