getting rid of web n walk
6 replies · 3,332 views · Started 22 August 2007
Hey Guys newbie here😊
i have just swapped my N73 for an N95
the 95 was apparently "locked" to T-mobile yet my O2 sim works fine in it
im having problems with using the web browser ie i cant i think its because the browser is Web n walk! does this make any sense to anyone and can anyone advise how to put original nokia stuff back onto it? i tried doing a nokia software update last night but that didnt work!
any advice/guidence appreciated
Thanks in advance
Rich
Welcome😊
If is a network version (not locked) maybe it does not have any new firmware.
To new how to install the last firmware version, search on this site for "NSS" and "change product code".
Why it does not connect to net, maybe is network settings. Use the inside application - Definitions Guide (or another word, I just made a translation from my native language) and install the definitions for O2.
what am i changing the product code to? (my current code is 0534841)
(im familiar with NSS because i used it on my 73)
It should not be necessary, if the phone already have the ME product code. it�s because of that, the best bet, for now, is only try to re-flash the same firmware again.
richydraper wrote:what am i changing the product code to? (my current code is 0534841)
Try a Euro 1 product code! Do the firmware upgrade and then check all settings! If any missing then go here_
http://www.filesaveas.com/networks.html
Just ignore the wap crxp!
BTW T-mobile W'n'W is one of the best data packages around! I'd keep it!😉
you boys are legends changed Product Code to EURO 1 (Plum)
now ive got rid of the NASTY HORRIBLE T-Mobile Software and im running a clean nokia build with opera mini and theres no more problems
thanks for your advice guys its all appreciated very much
thanks
Rich
richydraper wrote:you boys are legends changed Product Code to EURO 1 (Plum)
thanks
Rich
