Hello everybody,
I am having a little problem I am not receiving and multimedia messages.
I have a unlocked,non branded phone.
My carrier is T-Mobile here in the states Seattle to be exact.
I am not sure if I have to configure my N95 to receive multimedia messages.
I can receive text messages just fine.
thanks
yes I read the manual
hd2900xt wrote:Hello everybody,I am having a little problem I am not receiving and multimedia messages.
thanks
You need to find out what T-Mobile use for the Packet Data Access Point field (Tools->Settings>Connections>Packet Data>Access Point)
You could try editing the MMS Access point and copy the APN name the Packet Data Access Point.
thanks for the reply
I didnt know I had to do that, I figured when I inserted my t- mobile sim card it would automaticaly configure itself for text and multimedia messages.
thanks
I ll try it, hope it works.
hd2900xt wrote:thanks for the reply I didnt know I had to do that, I figured when I inserted my t- mobile sim card it would automaticaly configure itself for text and multimedia messages.
thanks
Yes, your MMS and GPRS Access Points probably setup automatically, but it seems the Packet Data connection is never automatically setup adter a format or Firmware change, not on any of the networks.
