N80 how bluetooth to save to card, not phone.
5 replies · 4,184 views · Started 24 August 2007
How do i change so when i receive a pic or music via bluetooth , how do i get it to download to memory card not to phone memory. i bought mine off ebay with out instructions. i downloaded the instructions in pdf off nokia.com and that was no help. i can't bluetooth direct to memory card. does anyone know how to?
thanks
You don�t. There�s the way that thing works. On previous S60 devices there�s a software for that, but not on S60v3 devices.
Its determined by where you store your txt messages. If they are stored in your phone memory they go to the phone memory and if they are stored in your memory card the downloaded pic or music goes there.
Hope this helps
yup theres an option in text messages to save to memory card, this will save all text messages inc bluetooth ones to memory card, so you can accept bigger files.
bestestimes wrote:[FONT="Arial Black"][SIZE="7"][/SIZE][/FONT]
Yes that does Help. Thanks a Bundle.:icon14: 😊
But that way, the phone behavior may became unstable and the connection of phone on USB Pen mode may be impossible:frown:
