Dash with Efficasoft GPS
0 replies · 3,799 views · Started 25 August 2007
New to the boards with a question, that I am hoping I overlooked, and hopefully not posting the the wrong area???
I have a TMobile Dash WM6 with the Efficasoft version 1.27 GPS program. The Visiontac GPS receiver I am trying to pair it with is located by the Efficasoft Program under GPS Setup Auto Search Bluetooth GPS Receiver, but then I cannot exit with the selections saved. The only options for the buttons are: Search and Cancel. If I perform the task manually, set the baud rate, and select the com port, it still does not allow me to go any further. I have set everything properly and powered down the unit, and I've tried using every button on the phone, however, there is no enter or done toggle. Has anyone had this problem? Can anyone help me solve this issue? Thanks!
