Using DivX on the N95
3 replies · 2,494 views · Started 25 August 2007
I desperately need some help with running .avi video's on my N95. I'm a complete newbie to the phone, so there may just be something really simple that needs to be done! I was advised to download DivX Mobile player, and have subsequently tried to do it, but am struggling.
After creating a Stage 6 account I downloaded the DivX player for the Symbian S60 3rd edition operating system. However, when trying to install this onto the phone, using PC Suite, I am given the message on the phone that there has been a "Certificate Error" and that the installation can no longer continue... Please help!
simple fix, simply change the date on your N95 back to 2006
after successful install, change back to 2007
works all the time 😉
Still not working... It just says that the certificate is not yet valid or the phone date is incorrect! I am using Nokia PC Suite.. Should I be doing it manually??
monica _69 wrote:simple fix, simply change the date on your N95 back to 2006
Instead, change the date back few months (Feb-Mar) it should work. The apps certificates are valid for 6 months so if you change the date 1 year back it doesn't accept backdated time.....so should be few months.
