Can someone please put me out of my misery, even though I know I'll probably kick myself when I get the answer.
On the sub menu in my text inbox is a selection labelled Automatic find. Apart from highlighting the senders name, what else does it do please? I've looked in the N95 manual under Received Texts and can find no mention of it.
Inbox: Automatic find
hi,
it just does what it says,
finds automatically numbers and links. Then you can copy them into your contacts or edit a new contact. however its not very powerful and if you want to copy normal text out of message where it has identified a number it does not let you copy. So , I switched it off.
RR
Thanks RanRoubin.
I will sleep easier tonight.
End of blonde moment!
