hi community,
can someone give me any advise how to install chinese (system and/or other fonts) ? As an European living presently in Beijing, I do not want to change my firmware but I need to read and edit Chinese on my mobile as well as i need to install chinese software on it.
And, if i decide to change my firmware, i will lose all guarantee and service. Its bad enough that i had to learn the big NOKIA (worldwide active) does not give any support in China to a mobile which is bought in Europe. Believe it or not, i had many calls with support and CLUB-NOKIA.They only support a lot of nonsense and games but a real business man, who needs help in doing his work can not expect any help from NOKIA care line. They even did not allow the NOKIA Shop in Europe, which was willing to change my firmware, to get access to the Chinese Firmaware download.
So, help, help help
thanks in advance for any usable info
regards
Ran
This link may help you out a bit, it seems quite complicated.
http://discussions.nokia.co.uk/discussions/board/message?board.id=smartphones&message.id=29660&query.id=811656#M29660
I am pretty certain though that the only real way to get input in Chinese is to flash the handset with the APAC firmware though.
Kyuro wrote:This link may help you out a bit, it seems quite complicated.
http://discussions.nokia.co.uk/discussions/board/message?board.id=smartphones&message.id=29660&query.id=811656#M29660I am pretty certain though that the only real way to get input in Chinese is to flash the handset with the APAC firmware though.
You need to change your product code to one which includes the language set you need to use. In your case HongKong / Taiwan so
#0534832: Hong Kong
#0536084: Hong Kong
#0534830: Taiwan
#0536083: Taiwan
Will work for you ..
http://www.youtube.com/watch?v=uN9eRlddfH0 .. has all the links, to the software and a few tips to do what you need.
Good Luck!😊
