Anyone can mention the difference (with some screenshot if possible) between the 2 versions of R66 7.3.468 and 7.3.545.
Another question is if you make an upgrade to 7.3.545, do you need a signed sis for the new version, or it should be a clean install after remove the old version.
justnew wrote:Anyone can mention the difference (with some screenshot if possible) between the 2 versions of R66 7.3.468 and 7.3.545.Another question is if you make an upgrade to 7.3.545, do you need a signed sis for the new version, or it should be a clean install after remove the old version.
interface looks identical
I noticed faster gps signal, smoother display....UK and Australia friends report no more crashing....
you need to remove old route66 from app. manager, look for "Mobile7" then install new v7.3.545 clean install
leave maps where they are, do not delete them, new version will use previous maps
yes, it does need to be signed as well
how about new maps for Australia for ver 545? where I can get those from?
The best addition to the newer version is searching by postal codes.
i think 7.3.468 is much better because it locks on to gps sat much quicker then 7.3.545 i have tested this on atleast 8 N95 phones.
i am using 7.3.468 with latest maps plus postcode search is in the maps not the software as someone suggested before.
sajjid wrote:i think 7.3.468 is much better because it locks on to gps sat much quicker then 7.3.545 i have tested this on atleast 8 N95 phones.
Oh that's what I had understood, but apparently postcode search was already available in v486. Fix in v545 is very fast on my N95 though.
I need your help plz. I had route 66 7.3.468 working fine on my N95 and it was working fine till today. I decided to upgrade my firmware and it deleted the Route66 as well.
Now when I am trying to install the Route66 it has installed but when I try to run it from applications it crashes.
Do I need a new signed one� or is there any other way around�
Plz help me�
