Nokia N95 New User
2 replies · 1,776 views · Started 26 August 2007
Just got my Nokia N95 and having a few problems with it. I can't seem to get the Wireless Lan to stay on when I connect to a network. It disconnects after a few seconds. Any ideas? Also I cant get the GPS to work. Again any ideas would be great.
Andrew
menu | Tools | Settings | Connection | Wireless LAN | Options | Advanced settings | Yes.
There:
Automatic configuration | Disabled
Power saving | Disabled
For GPS, upgrade to v12 firmware ( http://www.nokia.com/softwareupdate ), or later (if/when available), and make sure you've your network operator's Internet access point settings for network connectivity.
andrewsexton wrote:Just got my Nokia N95 and having a few problems with it. I can't seem to get the Wireless Lan to stay on when I connect to a network. It disconnects after a few seconds. Any ideas? Also I cant get the GPS to work. Again any ideas would be great.
Andrew
To get a first fix can take up to 30 minutes! Just wait!
