Small problem with converter
1 replies · 3,520 views · Started 26 August 2007
I've noticed a small problem with the Converter utility on the 5500 (the one in Organiser). The list of conversion types doesn't fit on the screen, and only the top of the bottom one is visible. It looks like the application thinks the screen is bigger than it is. It's not a huge problem, but I wondered if anyone else had spotted it, or if there's any other apps similarly affected.
AndyM wrote:I've noticed a small problem with the Converter utility on the 5500 (the one in Organiser). The list of conversion types doesn't fit on the screen, and only the top of the bottom one is visible. It looks like the application thinks the screen is bigger than it is. It's not a huge problem, but I wondered if anyone else had spotted it, or if there's any other apps similarly affected.
I saw same problem(s) and I thoght it was about some font applications I used, but if it is same without fixing the fonts, yes it is a small problem/BUG I think! (Like the others😉
:P
