A media player that works?
2 replies · 3,724 views · Started 26 August 2007
Hi all,
The included media player in my P990i, to put it mildly, sucks. It plays a file for 1-3 minutes before the player closes. Same thing with the radio.
Does anyone know of a suitable replacement? I used OggPlay when I owned a P800 but it's not compatible with UIQ3.
Happy5,
You don't have SwissManager installed do you? If so check that you haven't got it set to clean up when idle.
Adam
Yes I have it installed and followed your recommendation. It works fine now!
That clean-up feature is kinda handy with this phone, but I can always clean-up the memory via Swiss Manager.
Thanks a lot!
