I have 2 questions
For the n80ie there is a option you can search for wireless lans on the display of the phone, its suddenly gone for mine anyone knows whats going on ??
and how do you delete installed themes ??
thank you😊
I have 2 questions
thank you😊
You can probably try to re-install the WLAN wizard. Just go to the:
Internet -> Download!
re-download & re-install again. That's how I fixed mine a while back.
You can delete the installed themes by going to Tools -> App. Mgr.
Unless if you're trying to uninstall the pre-installed ones from Nokia...I don't think you can delete those.
HTH.
just restart your phone
mine sometimes dissappears too... and then comes back on restart...
also, Flux's suggestion is a good one too if it doesnt come back fast enough
