Where can I view which countries maps I have downloaded onto my N95? I can't see how to list them on either the phone or pc
tia,
Tony
What maps have I got?
With Nokia maps loader you can see that.
nj7 wrote:With Nokia maps loader you can see that.
How? From what I can see Map Loader does not display any info about which maps that already are on my mem.card, only how much storage that is available (using maploader v1.1).
Nokia map loader doesn't show me what I've got loaded. It only shows you which countries are available to load.
If you click on the delete option it doesn't show you which maps are on your phone either, it just says it will delete all map data, or something similar :con?
Tony
asgp wrote:Nokia map loader doesn't show me what I've got loaded. It only shows you which countries are available to load.If you click on the delete option it doesn't show you which maps are on your phone either, it just says it will delete all map data, or something similar :con?
Tony
Yes, is like that!
