Making it easier to Tune In
4 replies · 2,634 views · Started 28 August 2007
Guest writer Ricky Cadden reviews TunIn.Fm, a free application/service pairing that provides much easier streaming of Shoutcast Internet radio. Just make sure you're on a meaty data plan before settling back to listen!
Just want to say thank you very much for the hint!! I've been so dissappointed that the Nokia Internet Radio doesn't works so well on S60v3PF1 devices thanks to the new limitations in the WEB application.
Now I'm more happy thanks to TuneIn.FM! It would be even better if it was somehow possible to browse the full Shoutcast catalogue though.
/Jonas
Just discovered TuneIn.FM. Thank goodness! I was getting a bit frustrated with streaming using other means, could never work out which links would and wouldn't work with real player for example. TuneIn.FM has a nice selection of stations too.
jamesb wrote:Just discovered TuneIn.FM. Thank goodness! I was getting a bit frustrated with streaming using other means, could never work out which links would and wouldn't work with real player for example. TuneIn.FM has a nice selection of stations too.
Also try http://www.wauw.fm
This mobile app can play internet radio and your local music files streaming on symbian devices (amongst others)
