Possible for Loudspeaker On By Default?
1 replies · 1,847 views · Started 28 August 2007
Is there a way to make a car handsfree profile on the N95?
I want a profile which has the loudspeaker on by default. This would be safer to make/answer calls instead of having to answer the phone, and having to look at the screen until the "Loudspeaker" option appears on the screen before being able to activate it.
Also having the backlight on all the time in this profile would be desirable, but this is not as important as the loudspeaker option, so please only reply if you know of solutions for (i) the loudspeaker or (ii) the loudspeaker and backlight together.
Thanks in advance.
I should have said please leave a comment if you think this is a good idea so that developers can get some idea of interest.
Brian
