Can't change connection for web feeds
1 replies · 1,995 views · Started 28 August 2007
Hi there!
I've saved many bookmark for feeds under the Web Feeds folder of my E61. However, it only allows me to connect to my feeds through a single connection. Let's say, I have two wi-fi connections, one called "Home" and other called "Office". I can select either one when browsing, checking e-mail, using messenger, etc., but when opening a saved feed, it only selects "Home", and never allows me to select another one.
Is there a way to change this?
Cheers,
Francis
My experience is that the feed reader is a bit busted here.
Personally, I keep Web's network settings set to "Always Ask". However, whenever I try to load a feed bookmark, it connects using the last Access Point I used without asking. If that access point, be it WiFi or 3G is not available, I have to do a little dance. I switch Web to always use the current needed access point, exit the settings, return, and set it back to Always Ask and then the feed reader properly uses the access point I last set.
