I have an O2 unlocked N95
I have a three uk sim in it.
I changed the product code using NSS and used the 0536062 EURO1 - Plum code....NSS reported change okay...
I then used the Nokia PC Suite to update the phone.
The Updater starts, finds the phone, and at the end of it all it tells me that there are no software updates.
BUT the current version on the phone is 10.0.018
So i changed the Code to the 0534841 EURO1 - Sand and tried again,,,,still no update available.
Please can someone tell me what im missing?
riverboat wrote:I have an O2 unlocked N95
Don't use the PC Suite "updater" .. use the "stand alone" program.
Available here http://nds1.nokia.com/files/support/phones/software/NokiaSoftwareUpdaterSetup_en.exe
switch off any anti-virus and firewall stuff you have on .. for the duration of the update.
Good Luck!😊
Hi
I followed you link but the page is not found
thanks for quick reply though
riverboat wrote:Hi
I followed you link but the page is not foundthanks for quick reply though
Lemme fix that...
http://nds1.nokia.com/files/support/global/phones/software/NokiaSoftwareUpdaterSetup_en.exe
darn global bit
Good Luck!😊
Yes i already have the updater to get the firmware BUT it does one of two things
1/tells me there is a firmware update then crashes with error message previously stated
OR
2/tells me ther i NO update
Very frustrating
Just had one more go before bed and this time it said new software available for the phone/ preparing update.
After a few minutes i got error telling me
"downloading software package failed. The service may be down or your internet connection may not be working properly.
Try again later..
i can confirm
internet connection fine and ALL firewalls turned off
riverboat wrote:Yes i already have the updater to get the firmware BUT it does one of two things1/tells me there is a firmware update then crashes with error message previously stated
OR
Very frustrating
Be wary of Vista BTW... you need to run in XPSP2 Compatibility mode with the pretty stuff turned off and preferably as administrator. ..
IF that doesn't help you may need to find another PC to run it on.:frown:
I've updated a few phones under Vista using the software updater 'as is' and with no problems.
PC Suite does consistently crash on me with the same error message if I try to restore a backup file from Content Copier, though.
Make sure you aren't using a USB hub to connect the phone. Try a different USB port on your PC.
Hi
Well i did EXACTLY the same thing about eight bloody times with it failing for one reason or another.
Got to 3am and i thought sod this one more go and i'm off to bed..
well it then worked!
so good thing, now running uncrippled version 12 using Euro1 code
BUT
one question i thought this removed the supplier branding too.
Why does my phone still show the 3 symbol?
BTW
Using xp service pack 2 all latest updates applied.
can't afford Vista on my FOUR pc's 😊
riverboat wrote:Hi
well it then worked!so good thing, now running uncrippled version 12 using Euro1 code
BUT
BTW
I take it the 3 symbol is at the top of the main screen.
Its called the Operator Logo and I think it sits in a different area of the phone. It's hidden to Nokia File Explorer but you can edit/remove it with other Explorer programs.
