route 66 map help
2 replies · 1,768 views · Started 29 August 2007
i have just installed Route66.Mobile7.v7.3.545 onto my n95 but i cant find the maps folder to put my maps into. can anyone please help?
You need to make a directory on your memory card - System\Apps\Route 66\maps and put the map files into there.
Also, you may well find that with .545 you don't get any voices playing. In this case copy the voices directory from your phone (\Systems\Apps\Route 66\Voices) to the same location on your memory card.
