Broken N95 screen
4 replies · 2,503 views · Started 29 August 2007
I walked into the corner of a table with my phone in my pocket and the screen is caput.
Can i get it fixed? where shal i take it.
Woodbags wrote:I walked into the corner of a table with my phone in my pocket and the screen is caput.
i'v seen some on ebay for around �35 fitting them tou self shouldnt be hard
just got quoted �45 for the carphonewarehouse to do it for me, i might go with them to be on the safe side.
Woodbags wrote:just got quoted £45 for the carphonewarehouse to do it for me, i might go with them to be on the safe side.
that aint bad, i just saw some replacement screen for £33 inc del.
just for those who are interested fitting it is easy, remove screw under the slider incl media key slider side.
there is a clip with the screen attached which just pops off. then just connect new screen and put everything back.
Attachments: screen2.jpg screen1.jpg
