Hi
I have a certain task that I want to do in order to test something.
I want to display a certain web page on Symbian N95.
I looked at the developers library and found the "Browser Control API Classes".
I found a function named "LoadUrlL" that loads a certain URL.
I tried to use it but didn't succeed.
Can somebody refer me to a tutorial / code snipped / guide or just explain to me how can I do it?
Thanks for the help 😊
Are you asking how to use APIs in C?
If so, try Forum Nokia (forum.nokia.com), where there are plenty of people who can help. Note that if you don't understand what an API (or C) is, you have a LOT of reading to do.
If not, and you want to load a URL into the Nokia browser, then use Options, Navigation, Go to web address, and type in the URL (or set it as a bookmark).
The Nokia browser supports a limited set of protocols and filetypes. Opera may be a better bet.
