I am absolutely in the dark when it comes to the above two issues..
I have no idea how to do one or the other, and to an extent, I am not too sure I even know the uses of sync.. May someone kindly explain to me to point me in the right direction..??😎 😎
Syncing and Connect to Internet with PC Suite..
Somewhat blurry question... 😉
Sync = syncronize contacts, calendar, to-do, e-mails with local client such as Outlook.
How-to? Connect N95 with cable, select "Syncronize" from within PC suite and run the initial setup.
Connect to internet = connect to internet from your PC using your N95 as a modem.
How-to? Connect N95 with cable, select "Connect to internet" from PC Suite and select your country and network provider.
You may have to run the "Get connected" option i PC Suite once before trying any of the above.
Doesn't work? => RTFM 😉
