Battery Indicator Missing
2 replies · 1,817 views · Started 29 August 2007
For some reason my phone just switched itself off, when it rebooted there were no blocks showing in the battery indicator.
Any ideas??
Even when it's put on charge the blocks don't appear as they usually would..
meganecc wrote:For some reason my phone just switched itself off, when it rebooted there were no blocks showing in the battery indicator.
Any ideas??
Either the battery is faulty (does it retain a charge or is it always nearly flat?)
Otherwise, perform a Hard Reset on the phone and see if it all returns to normal.
Tried a hard reset and nothing happened so tried it again and the second time it went back to normal.
Thank You..
