i forgot the N80 lock code, so my cell phone doesn't work...
i want to reset ......the prefactory setting.
please tell me how
imei:358361000248124
code:0527396
please help me !!!!!!!!!
please tell me how
code:0527396
ask CbCharlie on this forum for help. he is awesome. he will help you out with any problems. you can check his site out too cellularguy.net
i'm pretty sure he will check out this thread and help u out.
I believe the default lock code is 12345.
You can also try this,
"Turn off the mobile device. Then press and hold “3″, the “Green button” and “*” - Turn on and keep holding untill the phone fully restarts. If successfully, you’ll be asked to reenter the date, time, city, etc. Its tough but it works." http://thinkabdul.com/2006/10/13/tip-format-codehard-reset-nokia-n80/
