Need help with E90 Text Message (sms) Inbox
2 replies · 3,690 views · Started 30 August 2007
Hi.
In �Messaging� and �Inbox� where all received text messages (SMS) are stored on my Nokia E90 the name of whom I have received text messages from is listed with "Last name" followed by "First name", like this: Johnson Eric. I would like to change this so that it lists it the opposite way: Eric Johnson.
When I open up �Contacts� and check �Options� and �Settings� I find that �Name display� is set to �First name, Last name� (which is the way I want it). So when I scroll down the list of contacts they are all listed the way I want them to be: Eric Johnson. But for some reason they are shown the opposite way in the SMS Inbox.
Does anyone know how to change this?
Thanks!!
Jim
While I personally do not have this problem, what you could try (if everything fails) is to backup your complete phone using the Nokia PC Suite and also backup using the internal Memory program.
Then reset your device using the *#7370* method (default security code is 12345).
Also make sure that your device has been flashed with the latest firmware.
At this time the latest firmware for both EMEA and APAC is version 07.24.0.3
Good luck 😊
