installed bliin and keeps telling me searching for GPS then gives me a symbian error....does it work with internal gps ? any other good software like bliin ?
Bliin problem
also if you're using your internal GPS, you should still activate your bluetooth. the app searches for it and throws a 'hardware not found' exception if bt is not active. hope this solves your problem.
goodluck
bliin team
