Where can I find the special codes for the P1i ?
2 replies · 15,088 views · Started 31 August 2007
Where can I find a list of the keyin codes used for UIQ 3 software on the Sony Ericsson P1i phone and are these codes universal? For instance, there is a keyin code to obtain the current firmware version according to the user manual. The codes would save time over looking through menus and sometimes it seems the codes provide function beyond what is available through the phone menus.
JDesigner wrote:Where can I find a list of the keyin codes used for UIQ 3 software on the Sony Ericsson P1i phone and are these codes universal? For instance, there is a keyin code to obtain the current firmware version according to the user manual. The codes would save time over looking through menus and sometimes it seems the codes provide function beyond what is available through the phone menus.
use jogdial.exactly like this to enter service menu.
JOG DIAL UP * JOG DIAL DOWN JOG DIAL DOWN * JOG DIAL DOWN *
move jog dial upwards once , then press * move jog dial down twice and press * again move jog dial downwards and press *.
You will enter service menus .Hope u understood .😊
hm. I didnt understand.. :con? but did you have a look at the P1 white paper or any UIQ stuff on se ddeveloper world?
adn I would still like to know if the codes are universal?!
thx
