Ive been following this forum for a while Ive tried searching but it seems Im the first with a problem with sports tracker?
Ive lost my Activities if I go to start a New Workout I get no activities.
This all happened since I up graded my firm ware on orange...
Any suggestions? Please I've uninstalled it re-installed it and still no luck...
Flame me if Im being stupid but please some one give me a clew...
Gerrit
I posted this afew days ago, I've tried everything with no success. Can some one please help...
Gerrit
gerrit wrote:Hi,I posted this afew days ago, I've tried everything with no success. Can some one please help...
Gerrit
I lost my old activities in the upgrade process, but the application works just fine after the upgrade.
illuster wrote:I lost my old activities in the upgrade process, but the application works just fine after the upgrade.
The problem I seem to have is I cannot make any new activities? The Default ones have gone and the screen says no data.
This happens if I go to Settings or to New Work Out...
With no Activities it does not seem to be able to track?
Please help...
Gerrit
gerrit wrote:The problem I seem to have is I cannot make any new activities? The Default ones have gone and the screen says no data.This happens if I go to Settings or to New Work Out...
Please help...
Gerrit
Is SportsTracker installed on your Memory Card and not the Internal Phone Memory?
Try installing in phone memory - you may also need to delete the Sportstracker folder/data from the Memory Card before re-installing.
Thanks for that, you are right. I lost some functions when the software upgraded its self.
I never thought of removing the Tracker file. Truth be known I had never noticed it!
I had tried installing it on Phone and Memory Card at variuos times. Now it is all on my Phone memory...
Thanks for the help.
Gerrit
