What are the differences to these two N95 firmwares?
RM-159_EURO_12.0.013_v3.00.exe
RM-159_EURO_12.0.013_v3.01.exe
kedge wrote:What are the differences to these two N95 firmwares?RM-159_EURO_12.0.013_v3.00.exe
What is your source of info?
I have both exe files to use with Phoenix , you need to install v3.00 first but was wondering what the update v3.01 was for?
Right click and save as:
http://dl01.seliweb.com/files/nokia_flashes/RM-159_EURO_12.0.013_v3.01.exe
Just found this info also..
New Minor Packs Added for N95
*14th August 2007*
N95:
RM-159_EURO_11.0.026_v2.15.exe
RM-159_EURO_11.0.026_v2.16.exe
RM-159_EURO_12.0.013_v3.02.exe
RM-159_EURO_12.0.013_v3.03.exe
RM-159_EURO_12.0.013_v3.04.exe
RM-159_MEA_12.0.013_v3.0.exe
RM-159_MEA_12.0.013_v3.01.exe
RM-159_APAC_12.0.013_v3.04
kedge wrote:Just found this info also..New Minor Packs Added for N95
*14th August 2007*
N95:
RM-159_EURO_11.0.026_v2.15.exeRM-159_EURO_11.0.026_v2.16.exe
Very interesting!
They look like minor tweaks possibly rolled out to NSCs and then incorporated in the major udate releases through NSU!
Have you applied them?
Do you have a JAF box?
There is no difference in the firmware.
The minor updates add more 'Operator Variants' to the V12.0.013 firmware, for example the products codes for operators not previously covered.
If you are using the Euro 1 product code you do not need to install them.
Ratkat wrote:There is no difference in the firmware.The minor updates add more 'Operator Variants' to the V12.0.013 firmware, for example the products codes for operators not previously covered.
Thanks for clearing that up, I haven't even installed v12 over my v11 due to reading about keypad issues with V12.
kedge wrote:Thanks for clearing that up, I haven't even installed v12 over my v11 due to reading about keypad issues with V12.
If your going to do it check out my guide on my blog-
Any feedback appreciated!
