:frown: :frown: :frown: Does ne1 know how to remove the shotcut icons from the bottom of the screen? They are annoying and absolutely useless for me.... Plus they block the view to the wallpaper... :frown: :frown: :frown:
Removing icons from standby screen
Tempted to reply with a "RTFM" but...
Don't have the phone available right now but it's one of the options under "More" when in standby screen (...believe it's under "Settings" where you can select "Display" vs "Hide" for all the different types).
wanna tell you, "try before you post", but you can only hide the today bar from the screen... no way to delete the icons at the bottom of the standby screen
does any one know how to change them not deleting them .. i wanna replace web with contacts for example
Finally I found it ! It's stupid that this option is in this tab, but hey...
Go to: Tools->Settings->Phone sett.->Standby mode
Here you can change the startup screen menu (main screen menu).
Enjoy !
mido01222 wrote:does any one know how to change them not deleting them .. i wanna replace web with contacts for example
It is quite easy :
Highlight the icon you want to change and then go to More ---> Replace and there you can choose what you want to put instead of to old icon.
