Mp3: Does anybody else have this problem?
7 replies · 2,144 views · Started 01 September 2007
Basically I loaded a lot of music on my microSD card, thru a car reader, but when I refresh the music library on the n95 it tells me that there are 182 files found, where as on my computer it tells me that there are 312.
So almost half the files are not being picked up by the n95😡
Is there a 3rd party player that the n95 supports?
I have this issue with a couple of mp3s going missing; they were high bitrate (392kbps I think) but I haven't tried re-encoding them yet... Anybody know if the N95 has a maximum bitrate?
when you load them go to music player and in options go for "refresh music lists" and your files will load into the player
wayne
tanov wrote:when you load them go to music player and in options go for "refresh music lists" and your files will load into the player
wayne
Yes...we are doing that..as we have stated
are they definitely all mp3s? if you have wma files they wouldn't be picked up by the music player on N95.
Well in my case the same message was displayed when transferring only mp3s and also when transferring only AAC+ files..😡
I just downloaded Core player 1.1.1 and it handles mp3&wma, and has an equalizer, and u can choose which folder u want to play.
I am glad I dont have to use the builtin music player no more 😊
