Does anyone know what could be wrong. Everytime the phone is switched off, the phone prompts again at startup for the date and time and displays it as 01/01/06 and 9.00am.
Anyone know how I could fix this?
Thanks in advance
Thanks in advance
Are you using the original Nokia battery?
I bought a cheap 'original' from ebay for my N80, and I get exactly the same problem as you.......if I use the battery which was supplied with the phone, no problem at all.
does not sound like a battery problem. i just took out my n73 battery, put it back after about a minute, and the date/time was still there. something inside must be keeping the time/date.
if its a software problem, going back to factory default/upgrading firmware might help
if its hardware issue(which i think it is), contacting nokia might be best option if under warranty.
maybe its in the settings of the unit...i had this problem once but unknowingly I solved it when I restored my N73 back to its original factory settings.... and I told my brother about it, he said there is another battery in the unit and that might have gone weak....
