I copied some songs onto my memory card, and music player seemed to find them and put them into the "All songs" menu.
Now when I try to copy songs to the memory card, even when using Nokia Music Manager, it doesn't put them into the "All Songs" menu. Only the old ones are there. I can find them in file manager and play them from there, using music player, but not straight from music player...
Using a USB cable, N70 (non music edition), 1gb card..
😡 :con?
i've n70me and i was facing this pb try this out format using*#7370# or hold down green +*+3 while the phone is off then turn it on then tell me what happen ok byby
tyler152 wrote:i've n70me and i was facing this pb try this out format using*#7370# or hold down green +*+3 while the phone is off then turn it on then tell me what happen ok byby
That's not the answer for the problem. Go to music player -> Options -> Music library -> Options -> Update Music library
ratza wrote:That's not the answer for the problem. Go to music player -> Options -> Music library -> Options -> Update Music library
cheers that worked great, that other solution looked very odd.
