people i have an annoying email which wont delete , general system error appears ne ideas how i can get rid of it
wont delete
Try using a file manager applications (Seleq, handy file, file manager..etc) and delete it from there. Gotta locate it manually though.
I have the same problem.Cant be deleted,even witj FileExplorer,i'll guess i do a hard reset.
i think you need to delete the mail for both phone and server.
No you dont,mail will be deleted from the phone if you delete it from the phone only.Only thig that will remain is the message header but that is not my problem.
I had a problem with bugme sms installation and cant delete the remaining sis file from the install folder.Its not taking much space but its really annoying.
