using iTunes unDRMed mp3 files
2 replies · 3,070 views · Started 02 September 2007
I'm having a strange problem with mp3 files I've downloaded from iTunes plus (mp3 file with no DRM). I can load them, but my w950i does not recognize them/does not play them.
Has anyone else had any experience with this?
Dr. Siddons
Aren't the iTunes Plus files using AAC format (not MP3)?
Anyway, Apple has some non-standard changes done to the AAC files (presumably they add the buyer's info there for tracking purposes), and you have to remove the non-standard part/block.
I recall seeing an Internet site with an application do so, but don't remember where and what the name is/was.
Alternatively, Sony Ericsson would have to change the w950i to ignore such non-standard parts in AAC files.
Or, you can burn a CD using iTunes and then rip them back to MP3 files for real.
(Note, though, that the AAC format is already a compressed, lossy format where music quality has been reduced - or compromised, as some might say -, and re-ripping that to MP3, another lossy format, worsens the music quality further).
